Poor Experia SP
Pizaman
Poor Experia SP
I've searched and not found! My Xperia SP. Is in trouble. Here are some symptoms.
1. If I simply push and release the power button, it flashes green and nothing happens.
2. If I hold in the power button, the green light comes on for 10 seconds followed by the red light and the Sony symbol on the screen for about a minute. Then it shuts off.
3. If I plug in and hold the powers button in (wall or laptop) the same as # 2 happens, but it continually loops over and over again.
4. Laptop does not recognize when I plug it in so I can't charge or repair
I have pressed the yellow power button in the back and had it vibrate 3 times, but it does not turn on.
4 REPLIES 4
Phy
Legend
Legend
Try contacting Sony Xperia Support.
Thommo
Genius
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Pizaman
This starts to perform the repair, but my phone does't stay connected to my computer long enough. I then get an error message indicating that the update could not be completed because of connectivity.
Phy
Legend
Legend
In that case, contact your local Xperia support.
