Points battery performance on xperia x
Import
I'm not a heavy user but I'm lucky to great 8 hours battery life. I've turned off as much as I can see bug little impact. Stamina activated. Any ideas?
30 REPLIES 30
CameronT
@Import,
You will need to change to the full version at the bottom of the page. You should have the same account regardless of the browser you're using.
Import
Tried that but can't scroll across or rotate screen.
Import
Thanks Cameron. Screenshots attached
CameronT
Hi @timpotty,
You have a lot of apps running in the background. Is bluetooth, wifi and NFC always on in general?
ykphuah
Your Android OS is way too high.
The first line should always show Screen.
As for the Play Services, if you disable Location, you should be able to get it off your list.
Have you checked your accounts sync?
Import
WiFi only on at home and known hotshots. Bluetooth and nfc normally on as used regularly. Accounts syncing OK. Location now turned off.
CameronT
@timpotty,
Can you please see how it performs in safe mode? Basically, just do the same test as you did before but in safe mode.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/td-p/348008/jump-to/first-un...
ykphuah
Here's another link that talks about Account Sync:
https://www.reddit.com/r/Nexus6P/comments/50ihs5/psa_check_your_account_sync_if_you_have_bad/
Sounded really like your problem.
beckybluecat
I have shocking battery drain on the xperia x
I have had the phone about 4 weeks and it will drain 30-40% in 6 hours when I havent used the phone.
is this normal battery life?
checking the battery life in settings, it appears to be the system which is largely draining the battery, it is also in Stamina mode.
The only problem  i thought it might be is that 4g is quite weak where I work and it seems to come and go, I wondered if this was a contributing factor.
any suggestions would be appreciated
thank you 🙂
Lord_viridis
You can try setting it to 2G or 3G in the settings, it may be constantly switching between the two and 4G if a weak area
