Points battery performance on xperia x
Import
I'm not a heavy user but I'm lucky to great 8 hours battery life. I've turned off as much as I can see bug little impact. Stamina activated. Any ideas?
30 REPLIES 30
@Import
Do you keep WiFi on all the time?
what has used up most of the battery?
settings > about phone > status > signal strength > what do you see?
CameronT
Hi @Import,
In this situation I would advise to fully charge the unit to 100%. Once the unit is fully charged use the unit as normal till it reaches around 5-10%.
Once it reaches this amount I would advise to check in Settings > Battery > Show Battery usage, take screenshots of this page and post them here.
This will give us an accurate idea of what part of the phone is using what amount of battery. Once we have this information we can then identify the best course of action or troubleshooting.
Import
Thanks. Will do later
Import
WiFi off. Signal strength 92dpm
ykphuah
I used to have something like this with my Nexus 5, and it was caused by the Google Account Sync stuck in a state where it will keep on trying and it fails every time.
Go into Settings->Account And Sync->Google
If there are any errors there, try to disable and enable it back.
Import
I have the screenshots however through mobile site can't see how to attach? If I go to full site on phone can't see all Web page to reply. If I go and try and log in via chrome I can't log in.
Import
Are there different passwords for Sony more one and the support forum? I can't see my posts in Sony mobile yet both areas use same email address. Very confusing.
Kashton
Battery life is not great but nowhere near bad. It's very similar to the iPhone 6s I had. However, if you use it it definitely will use some major battery time I've found. Like now I've been on a few forums for the past hour plus and I've noticed pretty fast drainage now. Basically it's just an average output battery. Nothing special as advertised but it's not terrible either. My Moto Z Force on the other hand simply is amazing. The battery goes forever and the quick charge on it is much faster than the X quick charge. The X just has nothing more than a middle of the road battery. Still the phone or the X model is quite a good device as I had the XA first and it it's double the superior factor of the XA.
Import
Hi Cameron. How do I attach screenshots when viewing forum on mobile site from phone?
