my music player is not able to fetch music files from SD card . Is there any particular folder where i should keep the files or any other solution ??
Wait sometime and it will add the music from the SD card...
but if it still not working, use Sony's Media Go to add and order your musics into the music player! this program really helped me a lot!
Media Go: http://mediago.sony.com/enu/features
Hope it helps
you can try to unmount your sd card and mount it back in the settings menu, it happened to me once and i fixed it just like that
unmounting the card doesnt help .. does the MTP mode has anything to do with this ?? because i transfer files in Mass storage mode ...
