when i turn on my phone ( sony ericsson ELM ) the phone is strucked and the startup screen also not coming . the screen is fully white . nothing happens can't off the phone by the button even ...that's all ..........please help me soon.........................
have you tried to flash your frimware using wotan server or far manager?
the problem come's suddently i didnt do anything to phone ....... .... will it be ok after flash the frimwere .......?.... can u tell me a way to flash the frimwere ...?
the phone is not recognizing by the computer ... the deivice cant pair with the computer ... so how can i update the phone by using the computer
i assume you don't have the fast port cable?
i already have the cable .. how to do ... send me a tutorial......................
Have you tried taking the battery out, leaving it for a while and then replacing it.If this results in your phone staying switched off, then connect it to your PC while it's switched off and run the update service on it: the instructions will appear on your PC, but what you need to do first is connect the USB cable to the phone while pressing down on the phone's C button until the update service application recognises your phone. I hope this helps.
i got a error massage like this .... so what can i do for this ?.............................
start all over again
