So my xperia pro stopped working about 3 months ago so I took it to get fixed, turns out the band needed to be replaced. Everything was working fine until last week when I plugged it into my laptop and it completely froze on me and won't turn back on.
When I press the power button all that happens is the sony ericsson name comes up and it doesn't go further than that. Now it just switches to a black screen and that screen and when I plugged it into my laptop it wasn't being recognized.
What do I do?
The only thing you can do is perform a system repair and see if that fixes the issue
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
I tried that but it won't update and now all I'm seeing is a fuzzy screen and it still won't connect to the pc companion
I have a similar problem .
All the lights in the keyboard works but it has no visual screen, and when it starts it stays blank.
