Phone won't turn on or charge, unresponsive to all reset/restart procedures : Z3 Compact
alfie
Good day Xperia Care,
I went to bed with my Z3c at about 35% battery level last night. 7hrs later, there was no response from my 1.5yr old Z3 Compact at all.
I can only get the red led notification light to come on when the usb port is connected to a charger (or computer usb) via cable. There is no red light when connected via magnetic charge port.
I have tried all the combinations that include holding down power + vol_up buttons, power + vol_down buttons for short or long periods (upto 60 secs) with and without charger plugged in. Also tried holding vol_down button by itself and also while connecting the phone to a charger. Same goes for power button. The red led, if on, doesn't blink or change. No vibration at all.
Tried a combination including holding vol_down button when connecting to PC, phone is not detected at all.
I have also tried holding the reset switch (next to sim card slot) for short and long times, upto 120secs, as suggested. No vibration or any response.
I have spent the last 7hrs reading about this here and trying whatever solutions I could find, no luck at all.
Please help
(Latest system updates always applied and I usually only need to charge the phone once every 3 to 4 days, when it nears 15%)
4 REPLIES 4
profile.country.PH.title
MarlonUk1
just try charging the phone with the wallmount adapter without the button combination 3 hours plus+ then perform software repair using Xperia Companion again
if that did not fixed it then have your phone checked at your local service center Local support
alfie
Hi nolramlb!
Thanks for your suggestion. I just plugged the phone in again now, will report what I find in about 4-5 hours.
alfie
yea, that didn't work. phone was not detected by XperiaCompanion, couldn't begin software repair Slightly_frowning_Face
Emir1
Hero
Hi @alfie,
I am sorry to hear that. Slightly_frowning_Face
I recommend that you have your device sent to an authorized service center, contact your Local support for further assistance in doing so.
