Hiya,
I keep getting this notification that my SE mini pro is getting low on space...but there is 1.6gb on the sd card.
I have read a few methods about installing app's to allow me to use the SD as internal/primary storage but all have disclaimers about if it damages the phone.
So i don't really want to go down this route incase the worst happens so can someone please help me with a solution?
Thank you
the only thing you can do is then to delete some apps or files or back them up and then remove them.
You can also try clearing the cache on some of the applications that are taking up a lot of space through the same section as uninstalling an application.
