Phone slowly charging
WujuX7
My phone is really slowly chargind and sometimes its being interrupted. For 3 hours it was only at about 40%
12 REPLIES 12
Samuel1
Hero
Are you charging via the wall socket or via USB/computer? Are you using the phone when it's charging?
WujuX7
Via wall socket, no im not using it, its turned off
Samuel1
Hero
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
WujuX7
I did software repair about 2 or 3 weeks ago, should i do it again?
Samuel1
Hero
Did you experience these issues before the repair?
WujuX7
Nope i didnt
@WujuX7
Boot on safe mode and charge your phone again, make sure to use a wall charger and a micro USB cable NOT a magnetic cable
WujuX7
Its same on safe mode
@WujuX7
are you using a Sony's charger and cable? are you using a magnetic cable? have you tested other cables/chargers?
