phone restarts while calling
hi..i bought an xperia mini pro today(23/7/2012) and when i make a call after sometime the phone automatically restarts....no other issues are found..but cant make a call ...can anyone please help me out
4 REPLIES 4
Format It ! !
Settings > Privacy > Factory Format > Erase Everything
Hope this helps you ! !
hi sonuriaz...
i went to the place i bought the phone..they said to charge the phone 6hrs fully switched off..i hadnt done this.....in fact when i was charging i had to attend calls also....and also they said to change the sim..my sim is a reliance old sim.they told it may be due to poor reception of signal from the old sim..........i will also format as u have said..hope all will work fine, anyway thankss..il try it out and reply ...
cheers...............::smileyhappy:
hi....evden after doing all of the abovue there is no use.....i had no trouble calling for almost a day when at last the same thing becan to start again...now when i press the home physical key the phone restarts...what is this....:smileyconfused:
i think the problem is solved...gave it to errcson customer servce got an update to 2.3.4 and now it seems to be gone hopefull ..thanks all for the help Slightly_smiling_Face
