i Have Sony xperia T lt30p.
using flash tool i am upgrade to LT30_9.2.A.1.205_CH , when it updating system.sin not be flashed.green slider not move any more. i checked one hour but same result. my phone fully chaged.then i disconnected usb cable and restart phone only sony logo have screen.
next i unlocked bootloader using sony site it works done. then i restared phone only red light blinking , there is no sony logo or any screen. then i trid flash using flashtool 1.4 version phone connected flashmode . wen it flashing error message occured loader.sin file
03/020/2014 17:20:30 - INFO - Processing loader.sin
03/020/2014 17:20:30 - INFO - Checking header
03/020/2014 17:20:30 - ERROR - Processing of loader.sin finished with errors.
03/020/2014 17:20:30 - INFO - Your phone bootloader cannot be officially unlocked
03/020/2014 17:20:30 - INFO - You can now unplug and restart your phon
Why did you unlocked the bootloader? are you certain that you indeed unlocked the bootloader or were you on the process of unlocking it?
i'm unlocked it using sony official mobile site for update my devics. it successfully unlocked
You didn't had to do that, you could've just flashed your phone with flashtool w/o having to unlocked the bootloader, does it charge at all?
it chage some time( when plugin to usb show green light after that it show red )
try this
connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 1 or 2 hours > then try again
after charging whai can i do
Try either EMMA or Flashtool
i tried with emma it identified phone but tere is a message no serivce available
Sorry to hear that, you will have to contact Sony directly
