Phone lock
Menna1
Phone lock
Please i neee help i forgot my pattern password
2 REPLIES 2
profile.country.RO.title
_alexdon_
See this:
/t5/FAQ/How-to-unlock-a-phone-w-o-reseting-reformating-the-phone/m-p/927295#U927295
If that does not help,you need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
Jake-SonyXperia
Hi Menna1,
Welcome to the community,
In case you are using a Mac computer, I suggest following the below instructions.
And Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
Let us know how you get on.
