Phone heating up
Lawrence6
Phone heating up
after 20 months my xperia arc is heatng up at the top of the phone (by the camera) and then drains the battery.
i have replaced the battery but still have the same problem, i don't think it is the battery as that is at the bottem of the phone, i have reinstalled the sofeware and done a factory reset but still have the same problem
i take good care of the phone, have never dropped it and keep in a in case
i called t-mobile as the phone is still under guarantee, their telling me to knock off the wi-if when not using the phone, but i have never had to do this before!
or, the new battery could be a dud (so t-mobile are telling me) is there any way to test the battery by connecting the phone to the computer? Just so i can tell t-mobile to get there finger out and repair or replace the phone.
any help please.
Lawrence
23 REPLIES 23
Lawrence6
Hi Uliwooly,
thank,s but how do i upgrade myself?
How to manually update, downgrade, root 2011 Xperias
http://talk.sonymobile.com/thread/38251
Lawrence6
Hi Uliwooly,
thanks for the link, but it seems out of date, i cannot download the tools i need, can you or someone point me to the right place where i can download the latest flashtool and ICS i need to proceed.
i have had a look around google to try and find the tools and instuctions but not had much luck.
thanks for any help
check again, the links do work
Lawrence6
Hi Uliwooly,
sorry about this but i am having problems following you advice
would you mind explaining to me step by step how to download flashtool and ICS, after i have these flies i will be fine.
just so you know, i do follow your link, i click on download flashtool, the only one i can see is V0.9.11.0 can you let me know this is the correct flashtool to download.
when i click on download ICS for Xerperia Arc, it takes me to a page that tells me i have to download 3 parts! but if i click on part 1-3 it leads to another page that states the file or flies have been removed!
i am pretty good at upgrading or flashing (TV,s PVR,s etc.) but hitting a brick wall with this one.
thanks for you help and time.
jabirshah
Hi Lawrence
you can check the following link to manuall upgrade.
androidlegend.com/update-sony-xperia-lt18i-with-official-ics-4-0-4-firmware/
Lawrence6
Hi Jabirshah,
am glad you have replied because i know you have just upgraded to ICS
but, the link you have sent me is for the Xeperia Arc S
my phone is the Experia Arc.
or, does it not matter? can i use the same link and software
thanks/
jabirshah
Hi Lawrence
Yes all procedures remains same and just download the ICS firmware for Arc(Lt15i) from following link.
http://www.qosmodro.me/2013/01/all-xperia-2011-official-stock-firmware.html#.UeExsm1vrUg
Regards
Lawrence6
Hi Jabirshah,
i have ICS ready to go, but not sure about the flashtool
which version do i need, i have 0.9.11.0 but it does not show ICS (that i have placed in the frirmware folder) do i have to update flashtool and if so how do i do this, as i do not see an update when running flashtool.
and i find it hard to download the correct version of  flashtool from the link you gave me
sorry for being a pain
Lawrence6
Hi Jabirshah,
just to give you details-
i have ICS version 4.0.2.A 0.42
i am sure is the right version for the experia arc
I have flashtool version 0.9.11.0 is this correct?
i have delated data in the firmware folder and replaced with ICS, when i run flashtool i click on flashmode and it shows 4.0.2.A.0.42 but the boxs to the right are blank, i cannot see wipe data or wipe cache or no final verifacation?
am doing something wrong or do i have the incorrect flashtool
thanks for any help
(i cannot wait to update my phone!)
