Phone heating up
Lawrence6
Phone heating up
after 20 months my xperia arc is heatng up at the top of the phone (by the camera) and then drains the battery.
i have replaced the battery but still have the same problem, i don't think it is the battery as that is at the bottem of the phone, i have reinstalled the sofeware and done a factory reset but still have the same problem
i take good care of the phone, have never dropped it and keep in a in case
i called t-mobile as the phone is still under guarantee, their telling me to knock off the wi-if when not using the phone, but i have never had to do this before!
or, the new battery could be a dud (so t-mobile are telling me) is there any way to test the battery by connecting the phone to the computer? Just so i can tell t-mobile to get there finger out and repair or replace the phone.
any help please.
Lawrence
23 REPLIES 23
Sam
Legend
Legend
The heat is normal and is due to the processor working hard performing a task of some description. Please check what you have running currently on the phone and uninstall any third party apps like task killers or battery saving apps you may have installed.
jabirshah
Hi
I have purchased arc s almost 2 months before and sometimes my phone also get heated by itself even when i m not using it and phone in idle mode for long time and also drains the battery as well. once i removed the battery cover when it was too hot to handle i feel the heat at sim jacket place so that i think this problem is due to problem in sim jacket place and i am now using it without sim from a day or so and now it is not heating up by itself.
Any idea about what is causing this?
Thanks
you have to check whats draining your battery
if you have wifi on and you are syncing facebook, or any other social apps it will drain your battery
jabirshah
No i don;t use wifi much so it remains off always only if i require it as well as all background data services are disabled and background sync also off as well as i have also disabled all social apps as well. i have erased all my apps and data once and hard restore as well but still facing this problem, that;s why i am also surprised as well and still trying to figure out things.
One thing is that may be my sim slot area has some loose connection internally b;coz it is that place which gets hot.
Lawrence6
thanks for all replies,
i had reinsalled the Android sofeware using pc companion so i do not have any downloaded apps, only those that came with the phone.
i have not been on facebook, skype, etc since i did a reinstallation
the top part of the phone is too hot to be normal processing!
while the phone is idle the battery drains from 100% to 0% in about 30mins then the phone turns itself off.
this has started to happen after 20months of being a great phone for no known reason at all
i will remove the sim card to see if this a problem and get back to you all
jabirshah
Lawrence same thing happening to me as well, my phone also get heated in idle mode and battery drain quickly but not 100% and then my phone turn off itself.
I have removed the sim card from a day and a half to check as well and since then heating problem is not arised yet.
Further updates and finding will be share from everybody as well in a day or so time.
jabirshah
i have Upgraded to ICS yesterday and since then everything is working fine for me as i have kept my phone still on testing no third party software installed yet as well.
Phone not turning off in idle mode now as well as heating problem is also solved.
Lawrence6
Hi Jabirshah,
after taking to T-Mobile i am ready to send back my phone for repair, before i do this i will try and follow what you have done, but i need your help.
how do I upgrade to ICS, When i connect my phone to Sony pc companion it tells me i have the latest software!
my phones details tell me that i  have Android version 2.3.4 is this ICS?
if not how do i upgrade to ICS
thanks.
most likely Tmobile is not going to release ICS on this phone, you can manually update your phone
