Phone Heating up alot
alihamzanaqvi
The phone is heating up alot even on apps that do not require much processing power.. any solutions to that or is this how the phone is after manufacture?
4 REPLIES 4
Miltos95
Seems a bit normal after a long use. Does the phone heat up then it's locked/in standby?
How much do you use the phone until it heats up?
Nabeel
The phone shouldn't become extemely hot.
If it's so then i sugggest you repair your phone's software to see how it goes,
If problem persists, get it checked at service center
nabendu
ge the sony function tester from theandroid  market !! got to phone facts and check the temperature !! high use can tend the temperature to rise to 40 degree celcius !! also upto 45 degree celicius could do but over and above will show something is seriously wrong with ur puece
ryan515
before repairing do this... and after repairing do this also. take screenshot of both.
