phone getting switched off on incoming calls
sidharth
Xv getting switched off when trying to answer a call or on ringing.also noticed a half of screen gets blue flickering sometimes when the keypad is working.it is after the 4.3 update
7 REPLIES 7
sidharth
hello,
my new sony xperia v started restarting a month back ago while i plug in the charger.it wont restart if i put the cable in and then put the switch on. i have a doubt of my micro usb port had got a small damage while i plug the cable once in a wrong way.will it happen because of that?actually i had an experience also before the micro usb port got the injury.one of the pins in the port got up and i made it down with a pin.wll it be the problem of rom or the hardware.i resetted it and having the same condition now too. Slightly_frowning_Face
gwhispererz
Hi, don't really understand, but it is best to send phone to the local Service Centre to examine the 'damage' (unless you can live with it).
I would suggest you to perform a software repair with PC Companion or Update Service to be sure it is not a software issue.
Be aware that this process will erase phone data completely, backup if necessary.
sidharth
manjuboyz
Hi sidharth
   It happens many times, i dont know what is the speed of the wifi you are using, even i tried once using wifi but i am not able to succeeded, so later used high speed broadband and updated , it installed perfect
what i am suggesting is , try connecting using USB cable and try to reinstall the firmware, it will fix the problem
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
sidharth
I got it downloaded and installed successfully when I cleared ma phone storage(device memory)... Thnk u
manjuboyz
Hi sidharth
     Good to hear it fixed, we appreciate your work, take care Slightly_smiling_Face
NOTE:
Take your phone to a Sony repair center
