I had bought a sony experia P in May 2012. since few days the battery life didnt even persist for 24hrs and now the phone is cmpletely switched off not even able to on inspite of charging for long. it said the phone is shutting down due to high temperature. plz help. wat is the poblem with it?
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
if you are using any case for ur fone, remove it and try SUS as johan said
