Can you check if your device can be charge when phone is switched off? Try another charger and also try with another power source like another plug. Also connect your phone to a pc and check if your phone is detected in pc or not.
If you experience the same with different cables and/or chargers then it might be a hardware issue, you will have to contact your local Xperia care
Also, are you using a wall charger? are you using a magnetic cable?
thanks for the reply.
I switched off the phone yesterday, it does not charge either. from 46 % battery, it went down to 30 % something withing a minute ! then I switched it off, and tried to plug in
I tried to switch on later on .. which was impossible
Indeed, I bought another adaptor/charger (wall charger)
the problem is the phone itself, something wrong inside.
anyway, it shows the quality of Sony and brand new items!
@uliwooly wrote:If you experience the same with different cables and/or chargers then it might be a hardware issue, you will have to contact your local Xperia care
