Phone does not boot correct
skywardfallout
i got my xperia today second hand so i needed to factory reset.... when doing it it was taking a long time but strangly looping the boot screen so i thought it had crashed but then it turned off and on agin looping endlessly with a red light i tried pressing little yellow off button for like 10 seconds it turned off and oagain with the same loop...... it keeps disconecting from my laptop too =(
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
