Hi, I'm using CE1 lollipop on my M2 (18.6.A.0.175), and I have an issue with performance of the device while the brightness is set to highest level. Launcher seems to be very luggish, generally the device is slower. And when I set the brightness to lowest level everything is really smooth. I did the factory reset and system repair on PC Companion, but nothing has changed. Does anyone have the same issue? Is there any solution, or do I have to count on some fix from Sony?
@uliwooly
Yes, I've tried everything I can think of, but the problem remains. I don't know what else to do. Anybody having same problem?
Phew, I was worried it only happens on my device. So, I hope Sony will roll out some patch with fix of our problem and improvments of the camera
Since Sony had confirmed the update fixing the camera and GPS issues, I really hope they'll fix this problem too, it's a bit annoying, that I can't set max brightness without losing smoothness of the device.
