my phone gaming experience has gone to good to worse after updating to ics .....i expect a new build from sony to see to it that this problem is solved ASAP
Android 4.0 has higher hardware requirements then Android 2.3 so the phones performance may be affected. This is not something we can fix, Android 4.0 simply has higher hardware requirements by design.
We do however recommend that you check more then one game if you haven't done so already. Not all apps/games are fully compatible with Android 4.0.
Depending on which phone model you have you can contact a local service location to have it downgraded to Android 2.3.
but i have seen a miro (my friend's) on which games work well...which is lower in configuration than my ray.how come a miro works fine with a 800MHz processor on ics but not a ray..
