pcmode-factoryreset
ferro91
pcmode-factoryreset
hi everybody im new! great sony xperia i have one the SOLA! i ask to you if i can disable the richarge when i connect my sola to pc? is it possible or it must recharge when i connect? there is an app for this?
another question, i have some little problems with ICS, when i lock the phone sometimes it lagg! i want to do a factory reset is it a good way to solve the problem? does the factory reset delete my apps? does the factory reset delete the ics update?
THANK YOU EVERYBODY Slightly_smiling_Face
2 REPLIES 2
Johan
There is no need for disabling USB charging since is doesn't affect the battery in any bad way.
A master reset is always good to do if you experience any problem. The reset will delete applications and information stored on phone memory but it won't uninstall your phone updates.
ferro91
thank you :smileyhappy:, and i have probably a problem with the battery, is it normal that it drain 1% in a minute when i use internet and i play games!?
