PcCompanion issue
iChaos
PcCompanion issue
Hi , As today I'm try'ng to get the news update for my Z2 v. 23.4.A.1.200 (btw what it does contain?) even after i receive two may from sony to do the update , I'm unable here what i do :
Open PcCompanion :
->Check update
->Let's the phone connected to pc
-> wit less than 2 second , getting error 13 which say check my connection & firewall
What I did :
Check my firewall add'ed pccompanion app + updater
get back to PcCompanion check setting ->  check proxy setting -> check connection it's say everything ok
so what to do?
Edit :forgot to say but I also uninstall / install it already before doing all these steps
6 REPLIES 6
xavinux
Enthusiast
Hi @xChaos
Do you have Windows 10 as your OS in the computer where you run PC Companion?
I'm at disposal for any question.
Best Regards,
iChaos
Yea , I'm using windows 10 and I'm using pc companion in this OS ... is that the problem?
xavinux
Enthusiast
Hi @xChaos
I suggest check if administrator right is working incorrectly.
Also try to redownload PC Companion -> install it
Best Regards,
komilAD
@xChaos There is an ongoing thread about this problem.
iChaos
I did uninstall & install back , set run as admin , also attempt to run with windows 7 comptabilities (not sure if right typed)
so far nothing worked , maybe with a virtual marchine with windows 7 can help maybe... or it is bad idea?
xavinux
Enthusiast
Hi @xChaos
I suggest to run the virtual machine on VitrualBox:
https://www.virtualbox.org/wiki/Downloads
Best Regards,
