x
PC Companion WiFi Connection
Blatnikov
Hi
So the phone connects fine to the PC companion over the USB cable plug the cable and the PC companion connects no problem.
But I want to connect wirelessly preferably over the WiFi (PC does have a BlueTooth)
I disconnect the USB from the PC and the Phone.
PC companion says No phone/tablet connected
I click how to connect
Select WiFi connection
Procede till Connect cable I connect the cable hear sound from both the Phone and the PC. WAIT......
PC fails to connect. Phone says the device alredy paired. Selecting Ok on the phone and finish on the PC
Disconnect the cable Phone PC
Any advice?
Ivan
5 REPLIES 5
Thommo
Genius
Connect the phone via usb then open Computer then right click your device and left click Network configuration and follow the connection procedure
Blatnikov
Thank you for the reply
Phone is conneceted to the PC I to This PC(I use windows 8.1)
And There is no network configuration
Thommo
Genius
Not sure why you don't have that option unless it isn't included or you have a closed network
Blatnikov
What is it suppose to show?
Thommo
Genius
Quick way of setting up wireless connection ie: not having to use a usb cable
