PC Companion: Sorry! Only Sony Ericsson phones are supported.
fisil
I have an Xperia D2303 M2.
I did a factory settings reset. Seems OK.
I installed Sony PC Companion
It updated to the latest version.
I have Windows 8 64bit.  When I plug it into my PC, I hear the USB connection sound. But I can't see my Xperia in the file explorer.
I then try to connect Sony PC Companion to my Xperia.
PC Companion says "Sorry! Only Sony Ericsson phones are supported."
That makes me sad.  It's like a mother rejecting her baby.
8 REPLIES 8
Thommo
Genius
What a crazy analogy - Try making sure your drivers are installed and also you may have to run Pc Companion in compatibility mode as Windows 7 - So blame Microsoft and their problematic inability to driver sign using Windows 8/8.1
Rickard
It sounds like your computer doesn't have any support for MTP which your Windows version should have.
Do you have a N or KN version of Windows (without Windows Media Player)? If so, download and install this package: http://www.microsoft.com/en-us/download/details.aspx?id=40744
fisil
Hi Richard, I have Windows 8 on a Toshiba laptop. I upgraded to Win 8.1 once, but it did not function at all.
I still have PTSD from that experience.
I downloaded Windows6.2-KB2703761-x64.msu
When I launch, it says:
Installer independent from Windows Update
The Update Is Not Applicable To Your Computer
(Actually, I have Spanish language Windows, so it really says
Instalador independiente de Windows Update
La actualizacion no es aplicable al equipo.)
Is there a workaround?
fisil
Windows6.2-KB2703761-x64.msu  is the Media Feature Pack for N and KN versions of Win8.
Tags (1)
fisil
I paid MS $150, now I have Windows Media Center !
But I still see.
PC Companion was not able to connect to the phone / tablet. Please disconnect and connect again.
I disconnected / reconnected many times. Same message.
Rickard
You don't need Windows Media Center to connect the phone to your PC. Support for MTP-mode is included in Windows Vista and later and with Windows XP or if you have a version of Windows without Windows Media Player all you need is to download and install the Windows Media Player.
What happens if you connect your phone to another PC? Does the same thing happen there?
fisil
After I had problem with another USB device, I decided the problem was in my Windows.
I had to reinstall Windows, but then it was fixed.
Rickard
Glad to hear that it works now and thanks for the feedback Slightly_smiling_Face
