Please help...
I have a issue today with my pc companion, when i turn my computer ON i received a message with my pc companion that it needs an update so i run the update however when it is about 55% it will stop and says installation error. I tried it so many time but still no luck, im stuck to 55%, so i tried to uninstall and re install the program but there are no changes. If i will not proceed with the update it will closed. Please see the attached error
Im just concern that i can not update my phone to 2.3.4 because of this issue. Thanks
turn your antivirus and/or firewall off
or
restart your PC on safemode (restart then press F8)
you can try
Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
