PC Companion Failed Connection
RicoRidzhuan
I have been using sony a long time since the merging with ericcson, i have use 3 androids by sony, The Play, The ZL and The Z2, all 3 of this phones ask me to do the software updates then failed halfway leaving my phone like a zombie,
i think it is not really fair for me to have the same problems with 3 different device?
i revived my ZL before with SUS software because the companion failed me , but now the company decided to discontinue the only software that works?
now i have a dead z2 when i turn it on its just said software update failed connect to PC bla bla.
this clearly upsets me as all the forum dont really help me,
3 REPLIES 3
Thommo
Genius
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
RicoRidzhuan
i did, and i makes me loss 4 months worth of photo that are very important to me. am really not happy
Thommo
Genius
You are advised to backup your device before starting an update
