This just came up on Androidforums so thought I would post a link to it here....
This question has been asked soooo many times and maybe this will be of use to anyone that gets stuck.
wait a minute, that means if i know your email, by typing NULL after too many attempts lock out, it will get me inside your phone?
Oooooh hadn't thought of it that way! Maybe. That's a bit worrying. See I'm just far to honest and upright and forget that there's some bad people in the world.
I personally don't use pattern lock having had a nightmare with it with my ditz of a teenager and I don't really want to try it out just in case it doesn't work and I'm forced in to the whole reset/repair thing.
Maybe we'll get some feed back from peeps if it does work... but then we have this whole other can of worms to look at don't we.
I've used the pattern lock and it works really well. It does get to you though when you are using phone and it blacks out within a second of you not pressing a button and you not only have to unlock the phone but the pattern lock as well.
I did use it at first, and it was quite fun, but seeing all the messages here about the problems caused when too many unlock attempts were made quickly put me off using it for too long.
Have you ever been locked out?
hi ed here i just bought a used x10 mini pro locked to O2 and with pattern enigma
locked on.reading your letters praising seusless after a couple of hours trying every
suggestion i first tried se update. software was updated ok but still those black +
white discs on screen.i realised i updated without O2 sim card then se update again
with sim it did the trick,phone was now open without any pattern to do your head in.
it does loose any info on phone unfortunately but i'd just bought phone.
hope this info is helpful to all.pc companion phone needs to be on whereas
se update phone needs to be switched off
kind regards ed callaghan sat july 13 13
