pattern lock issue
adi_sat123
pattern lock issue
when u charge or connect xperia sola via USB pattern lock will not work it will halt at some points
this is not noticed by all users but all SOLA's have this issue......By the way will there be a Jelly Bean Update???
4 REPLIES 4
Johan
If this only happens when connected via USB it could be the case of bad grounding. Check if you get this problem if you connect your charger or when you connect to another computer using USB.
shawn
i face this problem too...now everytime after i charge my phone, i have to restart my phone...
can u tell me the solution of this problem?
thanks!!!
BadUsername
I have the same problem too.
Disable glove mode and unlocking will work correctly.
Or you if you have a sreen-guard on, you may try removing it. If that works, let me know too.
BadUsername
Problem occurs on connecting with charger as well as any computer. Also, there is no problem while setting/changing pattern lock even with charger connected.
