I have been following several guides on how to partition my sd-card but everytime I end up with the phone looping at boot.
I have a xperia v with a 32 gb sd card. the card works but when I partition it to 2 new partitions the phone wont boot.
I have the first partition as fat32 and have tried to set the second as fat 32 and ext2 but with the same result.
All help are welcome.
How did you partitioned your card? Means u used any kind of tools? Through fone or through pc?
I found out that the partitioning wasn't the problem.
I tried to use an app: link2sd but that isn't compatible with xperia v yet.
So, does anyone know of any app like that to move apps or appdata to external sd-card? and not appmgr or other move to sd-apps that doesnt use the external card.
I think some apps are meant to be installed in phone memory... Other can be installed in SD card also.. For moving app, you can use app manager (but can only move apps that can be installed on sd card). And I think you have to root your fone to move other apps to sd card... I think rooting is a bad Idea... 😐
I will search for any available apps that can help you...
