overheating problem in xpera zl
dat71
Can i replace my xperia zl with xperia z...??? Because i hv faced so much overheating problm..i hv faced overheating during playing games,surfing with internet,video calling,video recording,at chrging time,...i have already replaced my xperia zl twice through service centre...after that also i am facing overheating problem in xperia zl...i am requesting to service centre to replace my xperia zl with xperia z...i am ready to pay the difference between xperia z and xperia zl.....
11 REPLIES 11
profile.country.RO.title
_alexdon_
themanspirit
Don't do it.
As a former ZL C6503 owner, who now owns a Z C6603.
With the Z being IP certified, IMHO not only does it run hotter than the ZL.
But it also suffers from both a noticeably inferior display, and loudspeaker output, as verified by GSMArena.
Not to mention the headphone jack on the Z is hidden under a flap.
Which I find most annoying?!
It's pleasing to see Sony resolve this with a better solution found in the Z1.  :smileywhew:
Be aware that even the Z1 heats up too.
Which highlights when you pack this much processing power with Full HD displays.
Heat is an expected by product when there are no cooling fans, nor heat sinks.
IMHO you're being unrealistic not to expect heat from the current generation of Z series smartphones.
They all do it, to varying degrees.  Nerd_Face
dat71
But mr.adviser my xperia zl heats extreamly.....u will not believe i can feel like "now phon will blast now phone will blast" like that....it feels really hot...i want permenant solution for that....processor gets heated so much...i cant handle this.....
themanspirit
If your local authorised Sony Mobile service centre has found that both your ZL's performance, and resulting heat output, to be normal, and within specification.
Then what you are experiencing is perfectly normal.  Neutral_Face
All the Z series smartphones generate heat to varying degrees.
They are designed this way based on the materials of their construction.
To dissipate heat otherwise the heat will fry the internal components.  Nerd_Face
That's why IMHO you will find the Z, with its IP certification, and glass back, will not provide cooler handling than the ZL.
It's for this reason I don't use a case with either my ZL, nor my Z.
To ensure they stay as cool as possible.  Four_Leaf_Clover
moonsand
If with same usage "Z" also heats up so much it can also lead to back glass cracking and that is more expensive deal. So forget about "Z". There have been many reports of back glass cracking.
moonsand
ZL is too slippery without  acase. It's almost a similar feeling as holding Xperia P as far as fear of slipping out of hand is concerned.
dat71
Finally z or zl.....????
themanspirit
Thinking_Face  There's enough information here for you to make an informed decision.  Four_Leaf_Clover
dat71
So wht do i do.....?????
