Overheating making error on devices
experiencing the same problem..
error Back & Menu when hot conditions..
model number: ST15i
build number: 4.0.2.A.0.62
please,give me a solution this problem..
INDONESIAN
Nabeel
It must not overheat..
Try to perform a software repair , but if the problem persists even after repair then you must get it checked at service center
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
