overheated again
a6rnh
overheated again
Trying to show my friend the dinosaur, fish and fairytale AR effects with the camera but surprise, surprise it's overheated and shut down again. This is rubbish.. I'm on firmware. 402. This is embarrassing sony, when are you going to sort this?!
11 REPLIES 11
profile.country.RO.title
_alexdon_
Did you try settings-apps-all-camera,force stop and clear data?Restart.See if it will heat up so much.
alexdon
davidcristina2
3 or 4 minutes, with the camera in automatic mode and overheats. and if it's a hot day less time, follow the steps to reset the camera and as usual, I've installed an ultra fast microsd card and as usual, is but the history of mobile sony
Zann_H
Enthusiast
The camera overheating issue was fixed on .438. not .402.
a6rnh
And. 438 is still not available for me from the software site...
tel033
are you sure its been fixed in .438? @Zann.H
Zann_H
Enthusiast
Fixed, most probably. But improved, definately yes.
I used to only be able to record 4K for less than 53 secs. Now at 1 min, it barely feel warm. I manage to record in 4k up to 5:43 min. That's 5x more than it originally could. At least for my phone that is. And recording at the same location.
But some will definately cry foul because 5 mins is not enough. Well, don't record in 4k then. Z2 uses software encoding, not hardware encoding unlike a proper 4K Videocam. On those devices, you can record them as long as you want. And this applies to other 4K video capture capable smartphones from other brands as well. This is a limitation to the current technology at this this time.
 If you want to use Z2(or other smartphones) to record a long 4k movie, you better have a proper cooling systems. If not, get a proper 4K videocam.
a6rnh
What about the augmented reality app? Does that keep running?
Zann_H
Enthusiast
I was playing with it for a good 7-10 mins, showing off to my iPhone trotting friends, before it gets hot and have to shut down. It would be mroe fun if i can test it longer. oh well.
Mih
Is this the Kernel version's first 3 numbers that we are talking about?
thx
