Hi @Moaiad_Obeid,
I am sorry you're having troubles with your SIMs. Let's try to figure out what's happening here.
If you swap the SIM cards around, does it do the same thing?
I see. The next thing I would suggest in this case then is performing a software repair using Xperia Companion.
