hi guys,
i have got a sony SL. i would like to know how i can use offline Navigation Gps?
I used to have a Nokia N67, it had a software called Map. through this software i could get my possition on my city map. it could also help me to find my way out to the point i wanted to get. is there anything like this for Sony SL?
thanks.
You can see your position offline but cannot get directions or set route.
Do you have google maps? Usually it comes preinstalled.So if you don't have then download it from google play store.
Go to settings > location services > mark everything.
Running google maps for the first time needs wifi.
Run it, and tap on the option key on your phone. Select make available offline, adjust the selection area and download.
You could now find your position and see the map you downloaded, offline
Yes you can do offline navigation,download Navfree GPS app or sygic and download your city or state map then you can do offline navigation.
Regards,
Vivian Andrew
