My notification sound keeps going off every 10 minutes for no reason. I only hear it when I'm connected to a bluetooth item. I'm sure this has something to do with an app I have downloaded as it has only been happening for the past 2 weeks.
Can anyone help please.
Restart in safe mode(power button-tap longer on shut down-restart in safe mode).See how it goes.
Thanks for trying but that didn't work!
You could not restart in safe mode or safe mode did not fix your problem?
I rebooted in safe mode, but i couldn't test it as I couldnt connect to anything in safe mode, so I thought I had to reboot and then go back into normal mode?
Yes,get back into normal mode and see if you still have the problem.Cannot you remember what app you installed lately?
yes the problem is still there. I suppose the best thing will be to delete the recent apps one by one. If this isn't a common problem, then it must be an app.
Yes,it must be a call app,task killer,someting like that.Good luck searching.Unless you want to repair phone software,better find the app:smileytongue:
Thanks I'll get back to you if that doesn't work
Ok,waiting for your answer.
