led the problem during the call has not been resolved. it is always active. Only way to turn it off is to press the power button during the call:smileyquestion:
it goes o if you are on a long call and it also depends on the duration of display timer you have on if it's 15secs or 30secs or a min and above
hello,
during a call, the display turns off but the LED notification continues to remain even after a long time
it did not happen before the update.
thanks
Massimo
