notification led
dav
notification led
my notification led's of new Xperia L are working only in charging mode and during calls. How to fix d problem..??
6 REPLIES 6
Eren_Ackerman
Hi guys, I've update my Xperia L to 15.0.A.2.17 last two day. Everything was okay at once except the notification LED. the notification works properly when the screen is off(when there's incoming messages), but when the screen was on and there is incoming message I realised that the LED is the working. Is this normal? What should I do? I really hopes that someone can help me to figure out this prob.
Arie
The Xperia L has a very bright notification light. No problem at day, but at night it illuminates my whole room which is *very* disturbing.
How can I, like muting the phone's sound, disable the notification LED?
Basant
I purchased a rubberised back case which sorta covers the light n mutes it Slightly_smiling_Face
Cot88
Enthusiast
You can turn on stamina mode. It disables flashing led for call/sms/email.. notifications
But you can't disable green/orange/red led during phone charge
Cot88
Enthusiast
Check if you have enabled stamina mode in battery settings.
When this feature is on notification led doesn't blink for missed calls/sms....
If stamina mode is OFF try to boot your phone in safe mode and check if issue is the same
Method 1
  • Press and hold the power button
  • Long-press the “Power off” option that appears.
  • The next dialog box will ask you if you want to reboot to safe mode may pop up. Tap OK
    Method 2
  • Turn off the device.
  • Press and hold down the power key  until the phone vibrates.
  • Wait until the Xperia™ logotype disappears.
  • Press and hold the volume down key. The device then restarts in safe mode.
  • To exit safe mode, restart the device.
Hello i recently started seeing a bug with notification LED when using the sample stamina so no notice of anything or any social networking or messages or anything anyone haw any solution and found that the the upgrade was solved but 15.0.A.1.17 i live in colombia and it seems that is not available there any way to download it. Thanks
