Hello, I have a Xperia X10 Mini pro and suddenly my notification led turned always on, even when the cellphone is off the led is on and i can't turn it off. I have tried restarting it, removing the battery, restarting the system with the PC Companion and nothing works. Is there any solution for this problem???
You could try to reinstall the software using SUS and check if the LED goes off.
This solution didn't work either
