My smartphone xperia SP does not vibrate anymore.suggestions?
Did you look in settings-sounds to see if vibrations are enabled?Also,didn't you set the phone sillent mode?
Yes.vibrate is active but not found when message or calls arrived. I use Diagnostics app and not found
Force shutdown:
See after.
I have to reset a smartphone?
This procedure does not work unfortunately. The device still does not vibrate
