Hello. I have a Z2, update it stopped working but the front camera. Following that I wanted to load the previous software, but is now worse, not light. How I can ingresarar recovery mode to reset? Not recognize or computer to phone.
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
