Not ringing on outgoing calls
ee3
When a call comes, the phone rings normally.........but when I receive the phone call, the caller can hear me but i cannot hear the caller
And when i call someone the ringing is not heard.........in fact nothing can be heard,but as soon as i put the speakers on,the phone functions normally.I can talk only when the speaker is on. When i turn off the speaker its like i have muted the phone and not a single sound can be heard what the speaker is saying Crying_Face
PLZ PLZ HELP !!!!
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
