Not charging, now completely dead!
eriikberg
So when I was charging my z2 for while ago it started to switch from charging to not charging back and forth and the battery was slowely draining. And thwn it died and is completely dead and i can't turn it on what so ever.. Have also tried with a magnet connector charger and nothing..
Please help me it was only a month old.
Thanks!
3 REPLIES 3
Connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2 to 3 hours
profile.country.RO.title
_alexdon_
If the above does not work you may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Tags (1)
PC Companion (PCC)
Bridge (for Mac)
