- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Not able to shut down my Sony Xperia M.
Hey there !
Power/lock button is working fine as long as i use it for lock/unlock. But when I try to shut down my phone my long pressing the button, nothing happens. I don't want to shut it down by removing the battery because i am afraid that it might not start again.
I have tried pressing it for a long time. But still nothing happened. What should I do now ??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Power button and volume up at the same time,see if it works to shut down your device.But if you have a defective power button,you might not be able to turn it on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried pressing it but nothing happened. Power button is working just fine when i use it for lock and unlock. But the strange thing is that it does not work when i try to shut down the phone by long pressing it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You could try to remove the battery,but I am afraid you won't be able to turn it on.Try to boot the device in safe mode:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sir, actually this power off/ restart screen won't come up. Nothing happens ! it just locks the screen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In this case,stop by a sony serivce:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try a software repair and if that doesn't work then do as Alex above advised
To perform a system repair which will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey, I know it's been a long time, but I hope it will be helpful for others.
I had the same problem all buttons working, including the power one. But when I tried to take screenshot,or shutting down my phone - no reaction. here's what i did - i removed my battery(i didnt have a choice) and the returned it back. The phone must turn on by itself. I entered my pin and waited a few minutes. When i tried to hold it longer, the button was working perfectly. There must be something wrong with the software, but whatever.
Hope i helped
