When I go into settings security and then screen lock I get the message that settings have stopped, then I have to click on ok. This also happends after I start the phone in safe mode. I have done a software repair at least 7 times, and im getting tired of it now lol. After updating to android 6 i had nothing but problems with this phone.
can you try to reinstall Xperia Companion and or use another PC to perfrom the software repair using Xperia Companion
did you install or modified the firmware of the device before?
Even I am facing the same Issue, Camera is become worst, I am not able to change my pattern and not able to remove device admin. today proximity sensor started acting weird. I think i am not coming back to android again or at least for god sake to Sony. I understand today why apple is best.
Please fix these problem through update
Yes I tried safe mode but same issue is happening again. Now I will try once software repair too.
nothing has changed but now i can't even put a pattern lock and proxmity sensor issue is also there.
@YoGem wrote:
Let us know how it goes.
Yes, I did try that a few times. But nothing worked.
