My phones just stopped from ringing, it cant activates loud speaker nor pay music. ive chescked all sount or rings sttings nothing has changed.
Any help please
Settings-apps-all,look for smart connect.Clear data.Restart.
Hi Leekay81,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Can you advise if Message tones still work, or is this only subject to Music, Ringtone and Loud Speaker whilst on a call?
You could try running a Software Repair on the phone to see whether it brings the volume back for you.
Note: Running a Software Repair will delete user data, If you can turn on your phone & unlock the screen then you will be able to back up all of your data before running the repair.
Backing up your handset
To back up your phone using PC Companion
1. Go to Support to install PC Companion on a Windows computer.
2. When installed, start PC Companion on the computer.
3. Connect your phone to the computer using a USB cable.
4. Click Start under Backup & Restore.
5. Follow the on-screen instructions.
Running the software repair
Before you start you have to download the PC Companion software and install it on your PC.
Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Please ensure your phone is powered off and not connected to the PC when you begin this process. You are not required to connect the phone until after step 10.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
Hope this helps!
I am sorry to hear this, I can only really advise that you contact Sony Mobile within your region, they should be able to help.
Use my signature to find the correct contact details.
I apologize for this inconvenience.
