Double check if there's something in the 3.5 mm jack, it could be dust
Either this,or try to plug/unplug the headset during a call or while listening to music.
sent the phone in on warranty, if its ran out, try your customer rights, say something should last for 5 years, which is an acceptable amount of time, you will find the phone number here :
http://www.sonymobile.com/global-en/support/contact-us/country/en_GB/
I am having the same problem myself, and it seems to me that it's a bug within the latest 4.4 update. I know for a fact that it's a bug because when i press vol up/down button on home screen i can hear the "beep" sound comming from the speaker. Also when i go to volume settings and change volume for the incoming call i can hear the sound. When i play music in walkman i can't hear anything, as if the phone thinks that the headphones are connected. I flashed andorid 4.2, checked the sound and it's working normaly. I updated with PC companion and the problem appeared again. So i reset the phone to factory settings, and tried using the repair function in PC Companion, but no effect. I even tried flashing to 4.2 again and doing the OTA update, and still nothing. So i'm going back to 4.2 untill this is resolved.
