I can no longer access the sound picker from my phone? Whenever i tried changing my ring tone it pulls up the file commander.. There used to be a prompt for the sound picker.. How can i fix this?
Hi shuy_anne,
This sounds like you have chosen a default app. I suggest you do the following.
Menu > Settings > Apps > All > Sound Picker > Tap Clear Defaults.
Once this has been done, simply try assigning a new ringtone.
I hope this helps.
Clear Defaults is grayed out
Try this.
Menu > Settings > Apps > Press 3 little squares on top right hand side > Press Reset App Preferences.
Let me know if this helps.
Tried it.. it's still grayed out
This will stay greyed out, you should however be able to choose Sound Picker now in the list?
Can you please confirm.
hi,
i have read all 6 massages regarding the same topic. i have tried out resetting the apps. however, it istill gives "unfortunately sound picker has stop working."
i dont know what to do more. even i can not see the notification sounds in my phone. all are disappeared. after getting lollipop update, a start facing this problems. i am using xperia z1 c9603. please advise.
thanks.
ozgur
Try this:
- Go to Settings -> Apps -> All -> Sound Picker -> Clear cache and restart your phone.
thank you.
but i have tried all written advices above. even the tab for "clear default" is not active.
Clearing cache was not mentioned above, that's why I suggested it.
