No Signal/Bars?
AlanR1400
No Signal/Bars?
Hello, I purchased an unlocked Sony Xperia Z3 yesterday. I placed my sim in it but the phone keeps saying that there is no service and there is currently no bars. When I try to call it says I am in flight mode even though it is off. I had a friend who had this problem but it fixed itself, do you have any idea how I can fix this or do I have to wait it out?
14 REPLIES 14
profile.country.RO.title
_alexdon_
Is your nano SIM cut or bought like that?
alexdon
AlanR1400
Are you asking if I bought the sim as a nano sim? if you are it is a nano sim, not cut.
_alexdon_
Can you perhaps remove it and put it back? Check if the same problem occurs.
alexdon
AlanR1400
Same thing. I also tried putting my sim in another phone and it worked fine.
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
AlanR1400
Ok and how long does it normally take? Also should my phone be off?
@AlanR1400
If you have a fast internet connection it will take few minutes. The phone should be off.
AlanR1400
@uliwooly @alexdon
This did not work
@AlanR1400
Could you get a brand new SIM card? was the phone locked to a carrier/network branded
