Hello everybody.
I updated a Neo V and after the update my phone has no signal. Is this happened with someone else? Does anybody knows what can I do?
Thank you.
I would suggest reloading the software on the device as this sounds as though it is based on a bad installation.
You will be able to achieve this task using PC Companion which you may have used to perform the update on the device, simply select Repair and follow the prompts.
